Working on a leaky 1984 Ryhan-Craft riveted aluminum jon boat. In a day's fishing, it leaks enough to get your sneakers wet, a gallon or two. I filled it with water and located three leaky rivets. One rivet is completely loose and rattling, the other two seep just a drop every now and then. All 3 of them are accessible from both sides. I want to try re-bucking them first.
I have an air hammer and want to order the rivet setting tool "bit" from McMaster-Carr. The rivets look like "modified brazier" style, the head is around 0.5" in diameter, wide and pretty flat - not very "domed" or "mushroom" profile. Not sure about stem diameter, I suspect it is either 3/16" or 1/4".
I think this tool bit will work for re-bucking : https://www.mcmaster.com/6104A82 (with a heavy piece of steel or "bucking bar" held on the other side, of course).
I also ordered a bag of sealing blind aluminum rivets in case re-bucking doesn't fix the leak.
As a last resort I have a new tube of 5200 marine adhesive to smear on there.
I searched and read every topic in this forum with "rivet" in the title, so don't tell me to search - there is very little detailed info other than "use 5200 or some other adhesive like Gluvit or whatever" or "re-buck the rivet" with no mention of tools other than hammers. McMaster sells several rivet setting hammer bits, and they aren't too expensive, so I might as well use the air hammer I already have.
Thanks for reading - and helping.
