ober51
Man, you guys are way over my head. I like both, just don't want either to leak if I buy it.
CarlF said:Dont worry about riveted vs. welded.
Find a hull you like and can afford and buy it!
bassboy1 said:Most of the time, that porosity is in the top layer of weld. A process called back chipping eliminates that. Basically, when you run a bead, you go back with a carbide blade, either on a die grinder or even a standard skil saw, and chip off the top layer of weld. Then, run another bead, and keep chipping layers off until you get to where you need to be. I guarantee none of the big name welded tinny companies do it, but you will find on some of the bigger fishing boats made by custom companies up in the Pacific Northwest that this is a somewhat common practice.TrackerTom said:The problem with Mig's and aluminum is that the welds have porosity...
and they also don't penetrate anywhere near like a tig.
That is an apples to oranges comparison. Depending on the amperage of the welding machine, many MIGs can outdo the equivalent TIGs. You are right on the TIG getting better weld from the start, whereas the MIG, on a cold start, will take a few seconds to warm a thick piece of metal enough for a good weld. But, that can be solved by preheating the area you are going to start the bead at with a mapp or oxy-acetylene torch, and the initial penetration will be close to the same.
