If I use a decent primer right after gluvit is fully cured, is the paint gonna peel off the gluvit painted areas? The sanding task seems undoable. How can you sand around hundreds of gluvit-coated flat-top rivets before priming and painting? You'd never get it all scuffed. I mean, I'm patient, but nobodys that patient! Has anyone had paint peeling issues on unsanded gluvit treated areas with a good oil-based primer and paint? I'm guessing I'll be using the self-etching primer that is going on the rest of the aluminum. I really don't want to kill myself trying to sand all this again if priming and painting will be enough. Your thoughts are appreciated. Thanks!
