Sealkrete Gatorhide?
f4imatt
I think I want to try this on my new boat floor. I like the look of the plywood with high gloss spar and would like to keep that look on the floor. Have any of you guys used this stuff? https://www.seal-krete.com/gatorhide.htm Thinking one coat of spar, 1-2 coats with seal krete, and one last coat of just spar. Would this work?
It looks like it would work at least as good as mixing sand with paint but clear. If you wind up using it, post how you like it.
I plan on getting the floor started this week once I get the transom back in. Ill probably end up using it and hope it holds up. I will take detailed photos and post updates on its durability.
