Sears 12ft Jon Project
looks really good, im about to add the electric to mine, good stuff.
Today I bracketed on a piece of wood to create a storage area where the front bench will be the bottom of the compartment. I installed a toggle switch for the depth finder. Glued the foam into the floor, but forgot to take a pic. Started mock fitting everything together which was pretty cool because you start to get a feel for what it's going to look like when it's finished. I cut out the outer board for the transom, so once I can get some more staining done I'll be able to start bolting the rear together. I cut-out 2 doors in the top and bottom of the front deck for storage. Hopefully more to come here soon.
    50.1 KB
    43.5 KB
    51.8 KB
    485.9 KB
    55.1 KB
Installed some quick disconnects last night for the trolling motor. This way I will be able to pull the motor from the boat without having to mess with unscrewing anything. All I have to do is bolt the open end to the hub I installed in the front of the boat and we should be good to go. I also applied my 3rd coat of of spar-urethane to some of the wood pieces last night, so I'm hoping to get them carpeted and maybe installed today.
    423.6 KB
    445.9 KB
Today was a good day for the boat project. Hooked the quick release up to the hub. Wired in the toggle switch, cleaned up the wiring and screwed in the bracket for the depth finder. The stain on the transom pieces was dry and ready to be installed. My neighbor really did a great job routing the inner piece for me. Bolted everything in with a liberal amount of silicone. I even managed to salvage the old capacity plate from the old piece. I'm going to try and get some carpeting done for the front deck so I can get it installed and mock up the troller. I'm shooting to have this thing in the water by month's end and if everything goes as planned (which it seldom does) I shouldn't have a problem meeting my goal.
    499.5 KB
    57.6 KB
    47.8 KB
    80.9 KB
    40 KB
    45.1 KB
Thanks for all the updates on your boat. I've really enjoyed reading everything about it because i have the same boat. My question is, when you removed part of the middle seat did you leave the rib running along the bottom of the boat? Have you been able to take it on the water yet and see if there would be any structural issues? Thank you and I'll be continuing to follow your thread.
I did leave the ribs in to cut down on hull flex. Didn't make any sense to remove them as they don't interfere with the decking at all. Unfortunately, I haven't had it in the water yet. Although I've tried not to cut any corners with the build, having the boat in the water really is the ultimate test. I've definitely put in more weight than I have removed and the design of the transom could be troublesome if not sealed properly, so I am hoping everything goes as planned. I'll keep the updates coming.
Front deck done. It's amazing how well storage covers fit before you put carpet on them. On to the back deck.
    38.8 KB
    61.6 KB
    50 KB
Started working on the back deck. I've got a question for anyone willing to help me out. The rear deck goes all the way flush with the transom; however, I'd like to one day mount a gas motor on the back. I'm just wondering how big of an area should I cut out of the top deck so the motor will clamp in?
    48.4 KB
FOR MY 9.9 RUDE I NEEDED 9 X 14 CUT OUT IT GAVE ME ENOUGH ROOM TO GET MY GORILLA PAWS IN THERE AND DO WHAT NEEDED TO BE DONE
Thanks Bob, I appreciate the info. I was kicking around some ideas with my Dad of making an extended transom off the back to hook a motor to vs. clamping it onto the back. He's a really good welder so I know he could fab up something pretty solid. I may just put the deck on the back without making any additional cuts so I can at least get out on the water and then once I get a gas motor deal with it then. Plus the reservoir that I would mainly fish is electric only.
Home stretch. Cut everything out for the rear deck. Bolted on the troller mount. A little concerned that the motor shaft is a bit long for the boat; however, I haven't figured out if I can make it any shorter. Attached some cleats to the front deck. Clamped on the transducer mount I picked up from Basspro (didn't want to drill extra holes in the boat) to see how it would fit. Stained the last bit of wood. I'm going to try to get two more coats of urethane on tomorrow. Barring any complications I might just have this thing in the water next weekend.
    553 KB
    54.3 KB
    46.8 KB
    60.8 KB
    78.5 KB
Another question for you guys. Do you think a bilge pump would be overkill for a 12 footer? Debating.
If you have the means to put it in, there is no reason not to. It would suck to be in the middle of a lake and start taking on water, no matter how big or small your boat is.
Last minute add decided to throw in a bilge pump with an on/off switch. Ultimately figured I would rather put it in than regret it. Installed the floor, rear deck, and seat mounts. If I can get some work squeezed in tomorrow morning, I'm thinking I can have this project finished. Just need to test the electrical components, trim down the front seat post (it's about 6 inches too high), and add the side covers where the bench was cut out. That pretty much wraps it up.
    38.4 KB
    54.2 KB
    49.1 KB
    46.6 KB
    40 KB
    51.3 KB
    509.2 KB
    536 KB
    42.6 KB
Well it's taken me 6 months, but the boat is finally finished. Charged up the battery to test the electrical components and all system are a go. I'll see you all out on the water.
    79.9 KB
    72.7 KB
    70.7 KB
    76 KB
    69.1 KB
