jdh2550
I have a 65 lb thrust trolling motor that will be run on a 24 volt system. Should I install a fuse or not? If I should fuse it what size? I am thinking if I use a fuse it gets installed on the positive line close to the battery.
Yes, you should install a fuse. I would go with a 60 Amp fuse. Yes, it gets installed on the positive line close to the battery.jdh2550 said:I have a 65 lb thrust trolling motor that will be run on a 24 volt system. Should I install a fuse or not? If I should fuse it what size? I am thinking if I use a fuse it gets installed on the positive line close to the battery.
