Should I run this setup in parallel
mrdrh99
Omaha, NE
OK.... I'm attaching a diagram but some info. I have 2 trolling motors, 50# on the back, 36# on the front. Both transom mount. For the front I've wired in a Bigfoot switch. I have a 50a circuit breaker on the back and a 40a on the front. I have 2 batteries, and I've always heard that wiring them in parallel well increase your run time. With my setup, is this still a good idea? I'm sure there are certain days that one tm will be used more than the other. Any ideas, advice, input? Thanks guys!
Arent you suposed to wire the BF Switch to the NEG? Diagram looks good, id go parallel. Im doing same setup.
OK, so it's actually a th marine switch... But instructions did say splice into positive wire.
It's a done deal, used 8ga wire, butt spliced and heat shrinked all connections, everything works great, just waiting for a water test!
