I have heard nothing but good things about iPilot.
So I'm just getting started in learning what it's all about. Not what it can do but whats the setup...
What do I need.
I learned there is 2 types of iPilot.
1.) iPilot Link = which talks to my Humminbird and can follow contours and all sorts of other things. From what I can gather I have a choice of the Helix, Onix, Ion or the Legacy Units for my Fishfinder. Then I just choose what trolling motor I prefer. Thrust, Voltage, Shaft Length and Deploy Method.
Am I close?
2.) iPilot GPS Remote = Which has a hand held remote to control it manually. And will spot lock at the push of a button.
Correct?
I'd like to know what your set up is. What has worked? What hasn't worked? What would you do different if given the opportunity? What if money was no object? If you were in my shoes, wanting the most boom for my buck and not being able to ever replace it. What would you do?
What do I need.
Am I close?
Correct?
