starting a deck conversion on a Polarkraft 1436. It has a livewell in the center seat. I need to cover the seat where the livewell is with the plywood to make deck area bigger, but also want to leave the livewell in operation, so I would need to cut area out to access livewell. These are the questions - front part of boat is higher than seat with livewell where I would extend deck to - does it matter if the deck slopes or not? Also, how do you recommend supporting the deck? IT seems like just running 2X4's along sides and one down the middle would work - unless the slope messes that up. Width is so small there want have to be a lot of bracing side to side I wouldn't think?
