I have this unit.
https://www.amazon.com/Pyle-PLMRKT2B-Waterproof-Amplifier-6-5-Inch/dp/B009IAP54O/ref=sr_1_3?ie=UTF8&qid=1380805053&sr=8-3&keywords=pyle+marine+amplifier+2-channel
All has been fine in the month or so I've had it installed. Last night I starting to clean up my mess of wiring. When I pulled all the loose wiring together to zip tie, my right speaker started going in and out. If I held the connection from the amp to the speaker (soldered and shrink wrapped) it would come back on. I procedded to electrical tape this together hoping it would help. But my right speaker stopped working all together. Then my left speaker started doing the same thing. If I held the connection at the speaker wire in a certain way it would come back on. Any ideas of what is going on? I'm thinking my speaker wire connection is bad. It's just weird that it happened to both speakers at the same time. I'm thinking of cutting both connections and attempting to re-connect this evening to see if that helps.
