FishingBuds
kemical said:FishingBuds said:but i had 1 question..
what size bolt and nut is that you use on a aluminum boat..??
thanks again
On the bottom I'd go with at least a 10 head === IF and only IF its head seems flatter(less drag on water and get hung on trailer accidentally and strip loose) I usually used the number 10 head it seemed flatter-by the way it was a flat head screw drive type also-the phillips heads was fatter.
No washer on the head side-just a washer on the nut side-have the bolt long enough to poke thru (maybe a 1/4 inch long) and nut tighten up on it with said washer-with no washer on head side you will shoot it with the 5200(and I shot the hole too)
Your first photo looks just like what I uncovered on my boat too.
Your correct on hows it going for ya-that was the tuffiest part of the job in my oppion on stripping and bolts and painting
I'm excited for ya man-keep it up =D>
