propnut
hi i have a 1987 suzuki DT8 that has a charging coil with red, red/yellow and yellow wires under the flywheel but no rectifier. i have ordered a rectifier which has red, white, yellow and black wires. i found a wiring diagram for the motor online and it shows the yellow wire of the rectifier connects to the yellow, the red rectifier wire to the yellow/red of the coil and the white of the rectifier to the battery but nothing to the red coil wire. is this correct? thanks
