I have a question about my sea sense 6 toggle switch fused panel, the black one. I understand the fuse purpose and using fuses that are the correct size for the accessory that is being ran from a specific switch. However, when I received my switch panel today, the 3 toggles on the top row are jumpered into the 3 switches on the bottom. So there are six switches but only 3 fuses. I guess I was thinking there would be 6 seperate fuses.....So it seems that two switches are on the same fuse. Does this seem right? Then it says all 3 of the positive wires(that have the fuses), coming from the switch panel are to be wire tied together with the main red/positive coming from the battery. Is that correct?
I will be running my interior lights, and both bow and anchor light, and my livewell aerator from the panel
Thanks for the help guys/gals!
