pmshoemaker said:timsmcm, if you wouldn't mind posting a pic or two, that would be great! No rush -- no funds immediately available to do anything as of yet -- although it looks like I can pick up a section for the inside channel pretty cheap. My plan is for at least as much of the inside channel resting inside the outer channel as there will be extending past it to make sure the exposed length is well supported. Is this excessive? Like you said, my boat isn't that heavy. I can move it just by picking it up for now, but would like to add some decking which will add some weight. I completely understand your bolt inside the channel system -- what a great idea to double secure that set-up!
I will post picts of it as soon as I can. You will not need much funds to do this. Hacksaw, drill motor, drill bits, bolts and nuts, and your tongue metal. Also if trying to do it on a budget you might need a new tongue coupler. No welding needed just drilling. I say most men can do this but I am constantly reminded by my wife that I am utterly wrong In my assuming this to be true. So any help I can give I will and I assume others will help also. Will get picts as soon as I can.
