Terminal Fuse Question
linesider
Raleigh, NC
I'm in the middle of my new wiring for my jon boat and I'm looking for options for wiring the TM. I decided not to buy a new TM at this time since the boat came with an older Minn Kota 35# thrust. Until I buy a new TM I don't want to put the money into a more costly circuit breaker either. I just found out about terminal fuses and wanted to get the opinions of those here since I've never heard anyone mention them. I understand they function the same way as any fuse but I would think there would be an advantage to using the terminal fuse since it's placed at the battery and would protect the entire wire leading from the battery. What I can't find is if the fuse housing can be opened to replace the blown fuse or if the entire housing has to be purchased again. Thanks for the help!
I just use a 60 amp fuse like this spliced in 1 foot from the battery. I also carry a spare if needed and I never had a problem and they are not that pricey.
    5.4 KB
