lap202
So reading here the past year has lead me from "fully decked out super bass catching machine" to still probably unreasonably, but more plausible upgrading plan.
I have no idea what this boat is. It's 12' and has no HIN on it so I have to assume 60s or older?
The best part of the build is the large sum of money allocated to my 7 month son instead of my toys these days.
I got the boat out of a metal scrap pile on my uncle's land someone was throwing. It has been fished and hunted on a pond on my dads land for the past decade, but it was till this year we got the boat legally titled so we can take it out and motor the public lakes.
Phase 1
Monday I'm going to start by making boat seats to put over the metal benches. I got the foam out of a mattress pad someone was tossing and will cut plywood and attach the foam to the plywood.
I got some water resistant material at walmart which cost 5 dollars as they had it half off. This will be stapled to the back of the plywood to hopefully make cozy and somewhat decent looking seats. It will then be screwed to the bench.
Other than this I plan to check for and replace leaky rivets and do an overall health check of the aluminum. I'll also be stamping the HIN I was assigned into the boat along with an aluminum plate I'm riveting on the back.
Phase 2
I'm hoping to fish the boat June 2nd. Afterwards I'll be doing a small piece of plywood over the front bench that will be big enough to fit a rod holder and a cup holder (important) as well as storage underneath for the anchor and a couple extra ropes for tying off.
From here I'll have a small deck sitting on the triangle shaped ribs between the front and middle bench. After getting it in I plan on testing how the boat cruises and how stable standing and casting feels. Should be fine as I'm only raising my center of gravity a couple inches to gain some flat space.
Phase 3
Currently I'm just going to get my basic updates done. If the boat allowed I'd like to build a deck between the back and middle benches, but will be happy with just a front deck. Also would like to do a board at bench level between the back and the bench with hatches to have access to the storage but also gain some flat space along with places to attach rod holders for trolling.
Phase 4
Will just be making it pretty. Thinking I'll sand it down and do a dark green on the sides with a grey for the bottom portion of the boat.
Inside will depend on what carpet I get, but most likely doing a neutral grey.
Starting on memorial day so hope to get you guys progress pictures right away.
Sent from my SM-G950U using Tapatalk
Phase 1
Phase 2
Phase 3
Phase 4
