I installed a new impeller/water pump in a 9.9 merc,looking down the shaft in a clockwise direction..it will not pump water out the discharge tube, there is no obstruction in the discharge tube,so i thought maybe the thermostat was stuck shut,so i took it out sprayed some deep creep on it and got it loosened up,but it prolly needs replaced anyway, but i left it out...still no water being discharged. My question is,will it pump water without the thermostat in place or does it have to be in to build pressure?
