So I am in the process of putting LEDs on my boat. I was planning on using a toggle switch to turn on/off. I was going to run positive to battery with an inline fuse, ground to battery and third prong on switch to accessory. However, I read that you have to use a relay when using toggle switches. Is this correct? I have read that the switch will get hot and burn up without a relay. Confused.
