Touch up painting on the hull?
Seth
Owensville, MO
I've got several scrapes and chips on my hull paint from rocks, limbs, sand bards, etc. What's the best way to touch those areas up? Do I need to go through the trouble of wet sanding and spraying them with an air gun or can I just sand the spots smooth and slap some paint on with a brush? You can really only see the spots when the boat is sitting on the trailer and not in the water, but I like to keep my stuff looking pretty. :mrgreen:
It would really depend on how you want it to look. If the areas are not that noticeable i would just dab some paint in them.
Sanding and spraying with an actual paint gun would be a better repair but if your going to continue using your boat the wasy you already have you will probably continue to scratch and chip it up.
