BigTerp said:Chance said:![]()
Put it in the water for the first time to check for leaks and see what the motor would do. Dad took it for a quick test lap. Just a couple slow rivet leaks up front. The motor fired right up and seemed up to run great. I'm going to have to raise the console up though. I'm at least six inches taller than my dad.
A better way to check for leaks is to fill the boat up with the plug in while the boat is on the trailer in your driveway. You can then look from underneath and find any and all leaks easily. I do this every so often since I run by boat in a shallow rocky river and inevitably hit bottom from time to time. 5200 works well to seal up small weeping rivet leaks.
Thanks for the advice. I actually did do that a couple days before. Mostly just put it in the water for the fun of it. I think the 5200 will do. It is a very slow leak.
