Structurally it's all welded but I'm seam sealing it so I don't get any water through the cracks. In order to weld it all 100% it would take a lot of time and put a lot of heat into the material which can cause deformation which could potentially tweak the boat.derekdiruz said:Why did you not weld the whole seam of the deck, and instead sealed it?
I eventually want to have a buddy weld a deck into my boat, but don't know much about it.
Sent from my SM-G930V using Tapatalk
spcamno said:Very nice build!
I am currently working on a Sylvan 1750 Pro Bass similar hull to yours and convert it from console to tiller as a duck boat as well.
Do you mind if I ask why you have the light mount so high almost like a railing? And are you going to install a blind or not?
Also is the door / hatch aluminum or plastic and can you post link to it because I search Cabelas and can't seems to find the same door.
Thanks
hookedontronics said:spcamno said:Very nice build!
Thanks
The light is mounted up high to leave me room for a trolling motor on the front and also so the bow doesn't cut off the light output. The railing will also aide in keeping my decoy bags in place on the deck.
The door is aluminum, I'll try to find a link
