FINALLY got my boat and motor combo running good. It's a Tracker Sportsman 1648 with a '94 Johnson 50/35 jet on the back. Had her out last night by myself for the first time since we got the motor running good. Sonar reads good at low speed and at rest, but when I get up on plane the bottom reading turns to crap and the depth numbers blink, which I'm guessing means a bad reading? I have a Lowrance X-4, nothing fancy, but would like to get it to at least give me an accurate depth while running at speed especially since I'll be runing pretty skinny water with the jet motor. I had a small rooster tail from the transducer while up on plane, maybe a foot or two above the transom. I was by myself and have a stick steer setup, so no way to take a peek and see how the transducer was running in the water. Do I need to drop the transducer down? Adjust the angle? Or should I wait until I can have someone in the boat with me who can look to see how the transducer runs in the water?
