I have a G3 boat I want to add a fishfinder to. Problem is with mounting the transducer. I understand where/how it should be mounted but there is a welded "lip" where it should be. It's about the only spot far enough from the prop and in between ribs to avoid turbulance. Will mounting directly to this lip or above or to the right of it be alright? I'm wondering if it'll cause turbulance and cause the ducer to not operate properly.
Thanks...Bryan
Thanks...Bryan
