JohnnyKelly said: There are probably 30+ holes of different sizes and a giant hole about 1.5 ft.
And I haven't even started sanding it down.
whoooaaaaaa NELLY !! is that a typo ???? do you actually mean inches and not feet ??
an 18" hole is another issue all together !!!
Like Dale suggests - find out where the corrosion starts and stops.
then - cut out the whole transom panel and hone up on your metalsmithing skills.
no matter how you toast it - it is still going to be a lot of work.
providing you don't discover other "issues" once you start cleaning the rest of the hull.
