Derek
Is there a way to tension the trolling motor steeling cable? I have a MinnKota Edge 40lb. I have it set so when the pedal is flat it is straight. Although on high speeds the motor will bounce left and right. Probably moving about 15-20 degrees without pedal movement. Everything else works fine, just annoys me that I cant go "straight" on high speeds.
