Can some of you men tell me or show me the best ways to mount My new trolling motor? I have a lowe 14ft that has a semi v type hull that I am building a front deck on it. Does the motor need to be near the front point (or middle of the boat)? I am putting the terrova 55 on it and it looks like it needs to be close to the edge and after my deck is finished it will still be a little lower than that round piping on the top of the boat. What do you use as a spacer to lift the tm base up to clear this. I also wanted to know if I could get away with using t nuts to use to attach the tm because if I need to get the tm that close to the front of the boat there is no way I can get my hand under there to get the nuts and washers on the attach the motor. Also what do I need to get to wire up the trolling motor? Is there some kind of electrical center or other device to attach the power wiring to up front as I will wire heavy wire to the battery in back.
