ben2go
I have a Minn Kota 3HP TM.The prop shaft has rusted really bad.The prop pin is stuck.I tried using a BIG set of channel lock pliers and pushing it out.I also tried knocking it out with a hammer.No dice.Yes I soaked it in penatrating oil for nearly 2 months.I may try a friend's V block and press.I may just have to cut it off and drill the rest of it out.Any body have any other ideas.
