I have a MinnKota Endura 55 transom mount that's about 3 yrs old now. Saturday, it decided not to work. I figured the switch had gone bad (because it did about a year or so ago, and when I call MinnKota they sounded fairly certain that was the problem and that it was a common occurence with that motor.) So, after loading the boat up and taking a closer look, I realized that I could grab the prop and acutally pull it along with the spindle about 1/2" out and back in, meaning there was "slop" in the movement. I say this because I have another identical motor up front that does not do this. Once I pushed the prop back in, the motor started working, assumedly because the brushes started making contact again. So, I took the prop off and started digging down. First off, this area which I assume is meant to be water free, (because of the gasket) is taking in water. Not sure if the "slop" had anything to do with it or if the gasket was just shot, but inside was wet, and there was a fair amount of crud and carbon inside.
Has anyone experienced this "slop" in the prop?
Below the armature is a bearing that looks to just sit in a hole below the brushes, but I could not see or understand how any retainer clip would work.
