I have a Minn Kota Traxxis 55 trolling motor and need to install a fuse or breaker near the battery. I have a Tracker Grizzly 1754 jon boat and will have the battery in the stern while the trolling motor will be on the bow. I hope the 6 gauge wire will be sufficient, I'm not sure how the proper gauge should be determined. Not a whole lot of TM plug choices when using 6 gauge. I would like to see how you on the forum set yours up.
I also am confused on why some of the bow/stern lights are offered in either 2 or 3 pin. Is one for grounding? If so, how would you ground it on an aluminum boat? Any insight would be appreciated.
FlyBye
FlyBye
