wmk0002
For the past year since buying my boat new I have been using alligator clips and a bow placed battery for my bow mounted trolling motor. I'm finally about to relocate it to the stern and wire it up permanently with the proper sized wire and breaker.
So it looks like I will need about 40 feet total/roundtrip of wiring. My TM is a 45 lb thrust 12V motor and my research shows that 4 AWG should suffice for that length of run and will even cover stepping up to a 55 lb thrust 12v motor almost any size 24v motor. I am going to buy all of my wiring products from tinnedmarinewire.com.
My questions arise regarding two parts I have in hand already...the circuit breaker and female TM receptacle plug. Each of them come prewired with leads but the leads are a smaller gauge than the 4 AWG I need and plan to use. The breaker is either 6 or 8 AWG, but I plan on getting a new post style one so that I can keep a spare in case it trips and won't reset on the water. But I find it odd that Motorguide doesn't opt for a larger diameter wire for a breaker that should be close to the battery. Now for the actual TM receptacle, I think it is either 8 or 10 AWG. I imagine 6 AWG would be fine to use but ideally I would like to mate it up with 4 AWG like the wiring running to it. I guess my question is not really about the wiring but rather what I can replace the receptacle I have in hand with? I'm trying to do everything right the first time so I want to be extra sure about everything before I begin.
