Kinja
- Joined
- Jul 8, 2018
- Messages
- 9
- Reaction score
- 0
I have fished this boat before, but it leaked pretty badly and I let it sit for a couple years. But now I have finally started making progress on upgrading it.
First was the removal of lots of dissimilar metals including a brass drain fitting in the bottom, rusted steel screws and bolts, some stainless bolts and two oar locks that seem to have been made of potmetal but installed with stainless bolts.
Next came sealing the bottom. I bucked all the below-the-waterline rivets and applied some West Systems G-flex where needed. There was also the problem of the hole left after removal of the brass drain.
DaleH gave me some advice about sealing it. I cut a circular piece of 5052 aluminum to fill the hole and two rectangular pieces, one for each side. I cleaned the inside and out with acetone and vinegar then primed it with Zinc Chromate primer. That was followed by Wet Systems' G-Flex and rivets to hold the entire ensemble together. It came out pretty decently I think.
A leak test showed that I still had a decent leak in the bow where there are a lot of rivets. I added some more G-flex there, and then a few days later I turned it back right-side up and noticed some old silicone sealant in that area. I cleaned all of it out and then poured some Gluvit in that area and let that set. A few days later yet another leak test proved that the boat no longer leaked at all. Yay!
I primed the entire exterior hull with self-etching primer then added a coat of another thick primer for which I cannot remember the name (it was one of those that you had to mix in hardener) followed by Sea Hawk Aluma Hawk paint. I then coated the upper outer hull with Wet Edge Top Side. I much prefer the new look.
Next comes the inside.
