nelsonag
Hello All.
So I was given a Merc 18xd as a courtesy and it ran great to the best of my knowledge. Since everything was working great, I decided to mess with it to get more hp. I read on some forums that model merc is the same as the 20 and 25xd models with exception of the carb and adapter plate. SO... I did some research, found it was identical, then bought a WMC15a carb (same as 25 model) and put a new adapter plate on it. I put the new carb on and noticed that it will idle fine, will travel under low rmp fine, but when i gun it it will run fine for about 5 seconds then will cut out.
Also, I switched it from tiller to remote throttle, and had to mess with the timing arm and idle arms in the process. The motor runs fine with the 18hp carb after I was trying to diagnose the problem so I dont know if timing would be the case but I am wondering if it is maybe a sticky needle valve? or is there maybe a timing issue? I have read its hard to mess with the timing on a 2 stroke.
I cleaned the WMC carb and rebuilt with new gaskets and still have this issue.
