Water out of my exhuast
colescoconutz
Crestview, FL
Engine is currently blowing water out of the exhaust so Im looking into replacing the gasket under the powerhead as well as the gasket under the lower cowling. Everything is already taken apart but I really dont want to spend 50 bucks on 2 OEM gaskets. I have a roll of gasket paper for water parts and such but I was wondering if I can use Hi-Temp gasket maker in place of making gaskets?
What make and model motor are we talking about and where exactly is the water coming out? If it is coming out the exhaust ports then that is normal. If it is coming from the powerhead seal then you have a problem.
86 Suzuki DT 15, and it was coming from the side by side exhaust ports. It was also leaking around the powerhead seal as well though.
Seal the exhaust housing bolts with permatex...
