nbaffaro
I am looking for a way to wire my single bank onboard battery charger. Right now I have to go through and unscrew the connections so that I can charge different batteries. I don't see a problem with this but I am thinking there might be one. What I would do is wire up a 15amp switch to each battery. With the charger unplugged I would just turn 'on' the battery I want charged. When I want to charge another one, unplug the charger, turn all the switches off then go to the next battery. None of the batteries are wired in parallel and they are all on their own circuit. The only problem that I see right now is that they share a common ground, but all of the batteries should share a common ground at some point anyways.
