which trailer tires
crankbait09
Cincinnati, Ohio
are there good/bad trailer tires???
I am in the need of two new ones but am uncertain of which is ok to get.
I am seeing a number of trailer tires including rims for $30-50 each. one of the stores being Harbor Freight.
my rims are old and rusted so id prefer to replace the rim and tire.
currently, the trailer has these tires: 4.80-8
I had the same wheels & tires you do. I switched to the 12 inch types & wheels from Northern Tool. Probably same ones you've found at Harbor Freight. I think I paid &40 a piece for them.
Check Walmart, kmart, farm and fleet, tractor supply, cabelas, bass pro and ebay. I bought my last pair on ebay from Tucker tire. IIRC the brand is Deesong made in China, the price was good and the tires are great.
I used my angle grinder with a wire wheel to clean up rusty rims and repainted with rustoleum spray bombs.
I just got this tire and wheel combo from Harbor Freight yesterday as a spare.
https://www.harborfreight.com/12-inch-spare-tire-and-rim-44144.html
Seems like a decent tire/wheel for the price, and it is DOT approved. I'm only using this one as a spare though, and if I needed new tires as my main trailer tires I would have gotten something nicer. I agree with Rstewart that 12" tires would be a nice upgrade.
And yes, there are good/bad trailer tires. You want to look at the rating. Mine are rated B or 4-ply rated which is up to 750lbs. I'd stay away from 2-ply for sure as I don't think they are rated for highway travel. I'd also make sure you get something that is DOT approved.
[url=https://www.tinboats.net/forum/viewtopic.php?p=337214#p337214 said:
crankbait09 » 16 minutes ago[/url]"]so just because it has 8" tires now, that doesnt mean i cant go bigger? whats the advantage of getting 12 rather than 8?
With larger diameter tires you'll get less RPMs at the same speed than with smaller wheels/tires. This equals less wear on your tires and bearings. You'll also get 2" more ground clearance with 12" wheels. May come in handy at the ramp.
crankbait09 » Fri Dec 27, 2013 9:22 am[/url]"]so just because it has 8" tires now, that doesnt mean i cant go bigger? whats the advantage of getting 12 rather than 8?
12" wheels may make launching at shallow ramps harder.
[url=https://www.tinboats.net/forum/viewtopic.php?p=337226#p337226 said:
lckstckn2smknbrls » Fri Dec 27, 2013 10:34 am[/url]"]
Didn't affect me launching my boat at all & there is times when I launch from the bank without backing in the water. It adds bearing life & that is much more important.
after looking at my existing rims, i see a 5 lug set up. should i replace the wheel hubs for new or leave them as they are? If im not mistaken, if i dont wanna pack bearings and what not, i would buy a new hub which would have everythign already ready to go, right?
If it were me I'd tear the existing hubs apart and inspect the bearings. If they looked good I would just repack them and call it a day. Packing bearings isn't difficult and only takes a few minutes. Be alot cheaper than buying new hubs.
[url=https://www.tinboats.net/forum/viewtopic.php?p=337439#p337439 said:
BigTerp » Mon Dec 30, 2013 8:28 am[/url]"]If it were me I'd tear the existing hubs apart and inspect the bearings. If they looked good I would just repack them and call it a day. Packing bearings isn't difficult and only takes a few minutes. Be alot cheaper than buying new hubs.
What he said.
[url=https://www.tinboats.net/forum/viewtopic.php?p=337446#p337446 said:
RStewart » Mon Dec 30, 2013 10:15 am[/url]"]
What he said.
Even if you need new bearings and races it's not hard to change them.
i know it probably isnt the same, but the last set of bearings/races i had to do on a car had to be pressed in with a press of some sort. it was expensive and a pain in the arse for me to attempt on my own. i hope this isnt the same procedure
[url=https://www.tinboats.net/forum/viewtopic.php?p=337520#p337520 said:
crankbait09 » Mon Dec 30, 2013 11:21 pm[/url]"]i know it probably isnt the same, but the last set of bearings/races i had to do on a car had to be pressed in with a press of some sort. it was expensive and a pain in the arse for me to attempt on my own. i hope this isnt the same procedure
The races will have to be pressed in but it's not hard. Use a hammer & punch to knock the old ones out & use a press or tap the new ones in with a hammer. I've never used a press to do it, always tapped them in with a hammer.
[url=https://www.tinboats.net/forum/viewtopic.php?p=337524#p337524 said:
RStewart » Tue Dec 31, 2013 1:27 am[/url]"]
+1
