skyline223
I'm bad about "finishing" a project and then ripping it apart and starting all over. Yep, that is what I've done again!
I've had my 1984 Starcraft semi-V finished out as a bass boat for about a season. It worked pretty well for the purpose, but I've started doing most of my bass fishing out of a kayak. After taking the jon boat down to the gulf coast and fishing the grass flats a few times, I've become hooked on redfish and speckled trout! I've decided to repurpose her. So here we go, converting my 12 foot V-hull jon into a center console mini flats boat!
I've been able to run surprisingly skinny water in this boat, and that was with her maxed out weight wise. So this time I am going to take a weight-saving approach as much as possible to further increase the shallow water capabilities. I'll want to keep the decks open and clutter free - no more seats. I want to implement a very small center console. This will still be a tiller-steered boat, but I want the console to house batteries, electronics, depth finder, and switches as to keep the under-deck space clean and open.
To my knowledge I haven't seen a boat quite like what I want it to ultimately be (in 12ft at least). It will still be a slightly cramped boat, but for one of two average size people it should still be decent.
So the deck issue I still can't quite figure out. I want a full deck but I do not want to carpet it (carpet and sand don't play nice together). I was thinking about doing a standard plywood deck but top it with a 1/4 of particle board painted white. My dream would be a plastic like deck found on most saltwater boats, but I just can't think of how I could do that. Any thoughts?
Here she was as a bass boat
And now here she is all torn apart ready for a rebuild. Amazing how nasty the under deck areas get in one season... (Plus a little zinc chromate on some areas already sanded.)
The goal is to build something along these lines, in a 12ft aluminum package.
- Primary power will be from a 2014 Mercury 5 hp 4 stroke (just enough)
Minn-Kota Riptide planned in the future.
Poling platform planned in the future if possible
I will most likely repaint the entire hull white to eliminate bare aluminum oxidization issues associated with saltwater use.
Deck will be hard surface (no carpet)
