Froggy
The red and Black TM battery wires, I like to get 6 or 4 gauge, battery will be 5+ feet away from TM, you get that stuff at HD, Radio shack? just trying to go to the right store the first time, Thanks
russ010 said:I really wouldn't use the wire at HD.. it's not really made for this type of wiring.
Auto is a little better, but marine tinned wire is the best. But I would go with the Auto stores if you can't get any of the marine stuff.
You can buy it by the foot, and get it pretty quick from https://www.genuinedealz.com - that's where I get all of my stuff from and they will make the cables for you if you know the lengths
perchin said:russ010 said:I really wouldn't use the wire at HD.. it's not really made for this type of wiring.
Actually 6ga Cobra cable is specifically designed for DC power, not so sure I know what you mean???
Never thought of that, would it really work ok?bassnbrent said:get a set of jumper cables buy some ends and walah youv got it
UtahBassKicker said:Never thought of that, would it really work ok?bassnbrent said:get a set of jumper cables buy some ends and walah youv got it
Those must be some kickass jumpers!perchin said:UtahBassKicker said:Never thought of that, would it really work ok?bassnbrent said:get a set of jumper cables buy some ends and walah youv got it
I would not do that. Jumper cables are made for short term use, and would probably get extremely hot with the use of a troller. I'm not saying that it would not work just that I don't know how safe that would be. Besides a quality set of jumper cables cost more than you would spend on the wire anyways. I just got a pair last year that were $80.00 from car quest.
