So happy to have found this site. I've really enjoyed the conversion pictures, you guys have really done some nice work.
We work out of a 12' Jon boat with a tiller motor. We've had anything from 9.9, 15 and 25 hp on this boat in the two years we've owned it. It leaks and because of the way we need to strap it down to our trailer it's structurally deformed and all in all needs to be replaced.
We like the size and weight of this 12' Alumacraft boat but before buying a replacement I need to work out whether we can modify the new boat to better take the abuse we subject it to.
Here is what we typically carry:
- 2 men, one 200 lbs. and one 250 lbs.
- 150 lbs. tools
- 6 gallons fuel
- currently using a 15 hp motor
We are pushing floating boat lifts down the lakes, launching both the boat and lift from an aluminum i-beam trailer. We are limited to a 12' boat because both the boat and lift need to fit on the trailer we have.
Modifications we need to make our job easier:
- trailer winches, one on each side of gunnel to pull boat lift tight against bow of boat
- push knees to help keep bow stabilized
- reinforced gunnels to help eliminate flex when we strap the boat down to our trailer
- reinforce bow to stern to help eliminate flex when pushing
Looking for other ideas and overall comments on whether you think we should start working with an aluminum boat as a base to modify. Thanks in advance.
Here are a couple pictures to show how we use our current boat.
- 150 lbs. tools
- 6 gallons fuel
