ober51 said:
Russ, out of curiosity, did you get any of those electronics to work - FF or trolling motor? Looks like you'd need a miracle, but hey, you never know.
The fish finder actually worked... but not very good - it has broken lines in it, but I think it will still show the depths and stuff like that ok. I ran it in simulation mode and I could make out just about everything.
The trolling motor on the other hand fried. I hooked it up to the battery, turned it on and it did a quick spin and I'm pretty sure it said "not in this lifetime". So I traded it to another guy for some Hella spot lights because he wanted the mount.
The front navigation light actually worked when I took it apart and cleaned the corrosion off the connections inside the bulb housing. I put it back on, but I still have to wire it.
I haven't tried the rear light yet - but I'll have to replace the dome on it if I want to use it and it works. I have to move it though because it's on the wrong side - shouldn't that light be on the right side of the boat (if your looking at it from behind the boat towards the bow)?
