onthewater102
Matching the color scheme of the seats to the boat to the truck was a nice touch. Does the motor fire at all?
Thank you onthewater.. Unfortunately the motor still isn't firing up YET. But I did find a replacement coil and spark plug wire on SearsPartsDirect. I bought a tester that says the problem is in the ignition system so since I've already replaced the spark plug, condenser and points, the only place, that I'm aware of, is the coil. I tried a couple different marine shops. One didn't even want to be bothered with it and the other said it would be about $2000.00 to work it out. (translated to me as "I don't want to be bothered with it"). Next stop. Sears Parts Direct for $37.47 . https://www.searspartsdirect.com/cr...60A/0006/217/model-21759464/0247/1305320.htmlonthewater102 said:Matching the color scheme of the seats to the boat to the truck was a nice touch. Does the motor fire at all?
Not sure off the top of my head, I'll have to go out to the shop tomorrow and get that info.onthewater102 said:What is it you've got for a tester? Haven't heard of much being used on simple old outboards besides a multi-meter and maybe a timing gun.
Just checked it out and bookmarked it. Thanks so much.onthewater102 said:There are some great You-tube videos put up by a technician from Humminbird on how to read and interpret the information displayed as well as customizing settings etc. His channel is here https://www.youtube.com/channel/UC720StZgdcrn-Ldn7vY4v1g
Great idea on the marker buoys idea. I just happen to have some closed cell foam that would do the trick. Yes, this is my first fish finder and getting excited to go out and give it a try out. Get familiar with it and start learning some of the in's and out's of it.onthewater102 said:If this is your first fish finder keep in mind that unless you're doing a lot of vertical drop-shot fishing you're probably not going to be targeting the fish on your display while they're shown on it as you're only ever looking straight down. You can see a circular area with a diameter 1.5x the depth of your boat with their 60 degree sonar (IE in 8' of water you're looking at a circle on the bottom 12' in diameter so you're only able to see fish directly on the bottom about halfway up your boat assuming the sensor is on the transom.) What it really excels at is identifying structure on the bottom you wouldn't otherwise know was there,
Definitely make yourself up ~dozen marker buoys using 1oz surf fishing weights, cut up sections of solid foam swimming pool noodles cut into flat dog bone-like shapes and wind them with enough fluorocarbon fishing line to reach the bottom anywhere you'd be fishing. Just drop markers each time you encounter structure on your imaging. Best $10 I ever spent at Walmart as a kid! You can use them to mark specific pieces of structure or to visually mark a submerged outside weed edge/ledge etc. You end up making one pass scouting everything and marking it, then circle back and then fish all your marked spots.
Even now that I have the GPS on the fish finder I still use buoys to mark everything when I'm deep water structure fishing because they are a visual target you can cast to as opposed to guessing where something is based on a blip on a screen. The weights really don't disturb much so long as you pass by on the TM and hand place them in the water (rather than toss them & make a splash).
Thank you very much, SDG.. I appreciate your input on the build also for sure..SumDumGuy said:The before and after of that boat are amazing. You did some real nice work there Y_J.
Good luck with the forthcoming build.
