muskyhunter1978
- Joined
- Dec 18, 2023
- Messages
- 53
- Reaction score
- 76
- LOCATION
- Bellefonte, PA
I spoke on another thread about my plans on how to restore and fix a corroded transom on a Starcraft Superfisherman that I recently purchased. I got a pretty good deal on the boat, knowing it had some issues, but my inexperience overlooked just how bad the transom was. Bottom line, the transom needs completely gutted, cleaned up and the corrosion removed from the outer skin, then repaired. The previous owners had a swim platform on the one side and they removed it. Instead of sealing up the bolt holes correctly, they just screwed the bolts back in without any sealant. The bolts were removed by hand! The center of the transom wood is soaked and water logged which I believe exasperated the corrosion from the inside out. Also treated wood appears to have been used in the boat from the factory.
Summary of what my plans are.
1. Remove the wood and expose the backside of the aluminum skin. Take a flap disk and grind out as much of the corrosion as I can, then stainless wire brush, etc to get it as clean as possible. Then an acid wash to further clean any corrosion, etc I couldn't remove and clean up with the previous methods. Maybe use vinegar?
2. Take a new 1/16" thick sheet of 5052 and make a panel, roughing up one side and cleaning to promote adhesion, that I will then use G Flex epoxy to bond to the inside of the outer skin. This does two things. One, when its clamped in place, the epoxy will ooze out the holes that are corroded through, effectively sealing them off. I can then use additional epoxy on the outside to skim all holes completely closed. This also beefs up the aluminum a bit more.
3. Laminate up two layers of 3/4 NON treated ply using epoxy and then completely seal the new wood with a couple coats of epoxy. Fit it, drill all the holes, then redrill the holes slightly larger and encase the insides of the holes in epoxy as well. Install new wood and bolt it all back up.
I am going to use this thread to share my progress and pics as I work along as some expressed interests in my progress and maybe it will help someone else faced with the mess I have.
