Pale_Horse_Idaho
- Joined
- Mar 13, 2024
- Messages
- 34
- Reaction score
- 27
- LOCATION
- Northern Idaho
Hello from N Idaho...
Can I run down what I have and what I want to do and get some advice?
14ft Mirrocraft Deep fisherman.
1.5" thick 53 in wide 12" tall 50+ year old untreated unsealed unpainted transom. Amazing it held up this long!
New 4x8 actual 3/4 inch A/B Marine plywood ($165.00) special order Home Depot, no one carries this anymore.
What is the best 2024 easily obtainable laminating glue? If not easily obtainable then what is the best. (Ive seen wood glue get wet after it dries and it turns white and soft again)
I do not have clamps so can I just have my wife stand on it for 24hrs? Just kidding!
Can I use screws instead of clamps? What type? What coating and MOST IMPORTANT would I want a 3/4" bare non-threaded shank on top half followed by the screwed section on bottom so they don't push the wood apart?
Can I leave the screws in after bonding layers?
Once laminated what is the best outer coating and edge seal?
Do I want to put anything between the rear aluminum boat skin and wood transom? The old one had nothing.
Is it OK to use stainless bolts for the knee screw brackets? Dissimilar metals?
I want to put a heavy duty clamp plate on the outside and inside as the 25hp is rough on the boat skin. Should I bond these to the wood before outside coating or after?
Where can I buy the top trim? Looked at a few online sites and cannot find this size.
Thanks for the help. I don't want to have to do this again so first time right time kind of thing.
Where do I buy this dimension C Channel aluminum?
