Old Alumacraft Shallow V, New Design
Boating related questions, small projects, custom work and talk go here.
Big Buck
Post by Big Buck »
I finally bought one. I got this from a guy off of Craigs List for $500.00. It came with an 18 Horse Johnson, which a few guys have already told me how to convert that to a newer fuel line, thanks for that. I have not yet came up with an exact idea of what I want to do but I have started to paint. I have just got the bottom of the boat primered and hope to have it painted in the next couple of weeks. Time is short being deer season and all. If you have any ideas, please feel free to let me know. I plan on running a deck across the first two seats and a back deck and leaving just the section from the back seat to the next open. I would like to put the battery towards the front and put a trolling motor up front, a hand controlled for now, hopefully later I can upgrade to a foot controlled. I will try and keep pictures coming as I continue to work on it. I can't wait to get her finished. My goal is to have it completed by the spring crappie bite.
Post by Waterwings »
Nice deal ! Gonna make a great fish-catchin' rig! 8)
dedawg1149
Post by dedawg1149 »
nice rig i have one just like it it fishes good =D>
The fishing was good,it was the catching that was bad
evattman
Post by evattman »
Lookin' Good!! :popcorn: Ill be watching the progress!!
Cheeseball
Post by Cheeseball »
Sweet deal! Can't wait to see what you do with it.
If you want a suggestion on how to paint it. Maybe go with colors that represents something that you are into. Like a football teams colors, school colors... etc.
russ010
Post by russ010 »
You are probably going to be more happy with that hand controlled TM as opposed to the foot control... if you do a foot control, make sure you set your front seat back far enough so that you have enough room to move it around and can get comfortable... that's something I messed up on big time. If you do end up doing a foot controlled, you might want to consider pre building a recessed box/hole in your front deck to put it
ben2go
Post by ben2go »
Lookin good. :)
Post by Captain Ahab »
Nice rig!
I think your idea is perfect - deck from the middle forward and put in a pedestal seat. I suggest putting a low deck in the rear just so the floor is level.
If you move the batter forward build the battery compartment large enough to hold two batteries (or make two compartments) that way when you add a trolling motor you can install a dedicated battery.
Also, run a section of PVC pipe under teh deck on each side so you can easily bring electrical wires under the deck without having to remove everything
Big Buck
Post by Big Buck »
I am planning on running all eletrical to a fuse panel/switchboard back by the seat by the motor that way I can turn on/off my lights, areator, etc and then run a plug in to the front for the trolling motor and then also installing a 12 volt plug to run a spot light, etc. The pvc pipe will work great to keep the wires neet, dry and out of the way. Thanks for the input.
My boat does not have a drain either. Would you suggest just putting in a drain plug in the back at the bottom of the boat, or just put a bilge pump and putting a drain towards the top of the transom. I also need to put a drain for the livewell. I hope you guys have some ideas for me.
Also, I am sure someone has said something on here about a good paint to use, but i can not find a post on here. I am not wanting to spend alot and plan on using my wagnor power painter to paint it. Does anyone have a good paint brand to use. Can I use just regular outdoor paint? Or is there a special brand that I need to use?
Thanks
ben2go
Post by ben2go »
I brought this up recently about using tractor and implement paint.Just don't forget to use the recommended hardner as directed.Here's the link.There are others in the list of modded boats.
viewtopic.php?f=3&t=5338&hilit=tractor+paint
Big Buck
Post by Big Buck »
I have been reading and from what I have seen everyone recommends zinc cromite primer. Does this have to be used? I just used regular automotive primer in a spray can from O'Riley's. Will this not work? I hope that it will be ok, i really don't want to have to start all over.
Thanks
ben2go
Post by ben2go »
As long as the hull was prep properly and the primer mixed and applied properly it should be fine.Auto paints don't do well submerged in water.Primer will be covered by paint so it's should be ok.
Big Buck
Post by Big Buck »
Well I found time this weekend to get my first coat of paint on the old boat. I still have to get one more on there and I hope the weather is going to coroporate with me this weekend so I can get the final coat on. After that hopefully I can get to work on replacing the old chip board that they used on the transom. I plan on using 1/2 inch plywood, that I am going to treat and then covering that with 1/4 sheet metal and then using silcone around the edge of the sheet metal to seal off the wood. The project is coming along good so far, I also was able to pick up a livewell system this weekend and have also began work on my cooler. I got it painted tonight and also picked up a rocker swicth panel to install as well. Let me know what you guys think of the paint, I will try to get pictures of the livewell up soon.
Marc
Cheeseball
Lookin good! I like the color. Are you gonna cammo it?
Paint job looks good! 8)
