Q-14 (semi V) AeroCraft Project
Scott Mac
Post by Scott Mac »
Got a few more hours in today. Made a mock-up of a hatch and I need a spacer under my lid support frame work in order for the lid to sit flush with the floor. Cut out some hatches and framed them in. I love working on these types of projects in the winter. Not enough ice yet and the ramps are froze up. Guess I'll bang away on my tin.
Hatches in the front.
Hatches in the rear.
This is my mock-up hatch.
This is the plastic spacer material that spaces the support frame down allowing the hatch to be flush when closed.
Golf is for those who can't fish.
My 1963 Aerocraft semi-v build
https://www.tinboats.net/forum/viewtopic ... 21&t=28345
Post by fender66 »
Looking good!
Scott Mac
Post by Scott Mac »
Installed the bilge and ran a wire way from the back to the front. I will have a 12V and 24V system. The 24 is for the new Minn Kota I ordered yesterday and the power will be in the nose. The 12V will run 2 depth finders, bilge, nav lights and maybe interior lights. I pulled wire to the front for the nav. lights and a depth finder. Have to wait until next week to finish the electrical (waiting for an order).
Bilge pump, wire way and 12 Volt (U1 size) battery.
Bilge exit.
Bilge exit.
Wire way (PVC) thru the back bench.
Wire way (PVC) thru mid section.
Wire way (PVC) to bow for depth finder and nav. light.
This is the 24 Volt battery mounted up in the bow.
Scott Mac
Post by Scott Mac »
Trimmed up the hatches for carpet clearance and cut the rod locker lids. Need to touch up the lids and coat the added wood with "spar" so carpet can get glued.
Bow hatch configuration
Rod locker lid
Rod locker lid
Rear hatch configuration
Scott Mac
Post by Scott Mac »
The new 24 volt trolling motor arrived and it appears to fit just fine. It came with a free Hummingbird depth finder. I am going to attach the transducer to the motor so I can leave it up front. I am running the motor with a single 24 volt deep cycle battery.
A single 24 battery will power that monster. It is a BIG battery but lighter than 2 - 12 volt batteries.
70# of thrust should handle any wind or current...I hope.
Looks like there will be plenty of room.
fishingmich
Post by fishingmich »
Hey Scott, do me a favor. Take a couple of pics of how you run your transducer cable up the trolling motor shaft. I did mine a couple of years ago and I ended up ripping he cable in half. Gracias!
I fish, therefore I am AWESOME!
16' Smokercraft V Hull
15 hp Merc
Scott Mac
Post by Scott Mac »
As soon as I do it I will send you the photos. I know it will be tricky but it can be done. I think it will involve several cable ties and maybe some high quality tape. I am not crazy about tape but cable ties do not prevent rotation around the shaft. I'll let you know. Good fishin'!
manley09
Post by manley09 »
wow very nice so far. keep it up!
Saving for a Ranger bass boat...until then...
12' Alumacraft (V-hull) Build To Bass Boat!
Scott Mac
Post by Scott Mac »
I've been a little concerned that my 1957 10 hp Johnson would struggle getting my project up on a plane because of the added weight so I set out in search for a more powerful motor. Not that there is anything wrong with my 10 horse but running on a plane is where its at. After countless hours of searching, calling and e-mailing I found a dimond in the rough (there is a ton of rough out there). I picked up an original unmolested 1963 18 hp Johnson and I can now get back to work finishing the task at hand.
1963 Johnson FD 17 - 18 hp
That is original paint.
Looks good for 50 years old.
Appears that this was well taken care of.
798hand
Post by 798hand »
i want to know more about that 24 volt batt.
have you used one before
jasper60103
Post by jasper60103 »
Scott Mac wrote:I've been a little concerned that my 1957 10 hp Johnson would struggle getting my project up on a plane because of the added weight so I set out in search for a more powerful motor. Not that there is anything wrong with my 10 horse but running on a plane is where its at. After countless hours of searching, calling and e-mailing I found a dimond in the rough (there is a ton of rough out there). I picked up an original unmolested 1963 18 hp Johnson and I can now get back to work finishing the task at hand.
The new motor looks great. Nice Find. =D>
2018 Tracker Grizzly 1648
Scott Mac
Post by Scott Mac »
I have used that 24 volt (GC2 size) battery before but not on a boat yet. I will be testing it out this spring on my minn kota 24 volt motor. We have put them in golf carts with amazing results. Golf carts require 48 volts and we have done both (2) sets of 24 volt batteries or (4) 48 volt batteries. We have reduced the weight of (4) 12 volt batteries by 30%, reduced the charge time by 50% and increased the capacity by 30%. It is a lead acid - bipolar battery that we are getting ready to market very soon. We build them in Clare, MI and that is where I work.
BrazosDon
Post by BrazosDon »
Scott, you have done a really good job on your tin. I have an old Lonestar that I will use some your ideas on. Keep up the good work
Scott Mac
Post by Scott Mac »
Thanks BrazosDon,
I have to get back to work on it, there is sooo much to do. I see you have a couple older OMC motors. I have been very pleased with that older iron they tend to be reliable, easy to work on, great looking and you can still get parts. How do you like yours? Thanks for the nice words.
BrazosDon
Post by BrazosDon »
I got these two motors this last summer. The big one is a '57 Evenrude 18hp and the smaller one is a '59 Johnson 3hp. My mechanic said both of the motors had good compression and less than 10 hours on each one, like brand new. I got less than $800.00 in both of them. Not a bad deal. I have them on an '74 Alumicraft 14'x48" MV.
