help,i am stupid,(well first boat anyway)
shadow
Parkersburg,Iowa
When charging the battery it was on charger for an hour but only went to just under 5 amps,what is wrong if anything?or do i just not know what i am doing
What is your voltage and more importantly, how does your battery perform under load. The first and easiest thing to do is check your battery with a meter, get a voltage reading, then take it to get it tested at auto zone or somewhere similar. If the battery is good, look at your charging system.
