Finally done upgrading for now.
BoneDigger
Tyler, TX
The boat is a new to me 1996 1542 Alweld. I bought it used but in great condition. The previous owner made the floors. I added the foam, electronics, trolling motor, rod mounts, seats, etc. I'm pretty happy! This is a ton more room than my plastic SunDolphin had!
My only issue for now is the motor needs a water pump/impeller. The parts are ordered and should be here tomorrow.
I like that nice clean setup and the slide for the rear seat.
Time to go fishing. Let us know how you like the seats. I picked a couple for a build but, haven’t used them yet.
nice use of space. where did you get the tie down cleats for your blue tackle box?
I'll do that. Unfortunately, I had a little surgery two weeks ago that makes sitting kind of tender. But I'm hoping to test it out this week.
Work kind of kept me busy and then a couple of vacations. I finally got the boat out on the water yesterday and it's so much nicer than that plastic SunDolphin I was using! I am going to enjoy fishing out of this boat! Everything worked as it should, with the exception of a minor motor issue that I am hoping will be fixed tomorrow.
