flatheadsteve
- Joined
- Jun 20, 2023
- Messages
- 542
- Reaction score
- 651
- Location
- Berkeley springs WV
- LOCATION
- Berkeley springs wv
I have a rocker switch for my jack plate that has acted up the last couple trips. It only does it just after launching I hit the button and nothing. If I click it several times it starts to work and never an issue for the rest of the day. I've checked everything with an ohm meter all connections everything is good. Only thing I can think is somehow moisture is causing a bit of corrosion inside the rocker switch. The boats used enough it must only be a thin layer but this shouldn't be happening on a marine grade rocker switch ( th marine) . I bought a spare switch to keep onboard incase this one gives up the ghost but it's the same brand so I have little faith. Anybody know of a high quality 3 position rocker switch that won't do this
My search brings back a bunch of brands I've never heard of.
