ScouterJames
deadkitty said:Hey Scouter! Sorry took me a bit to get back, been outta town. So this was my make shift cheapest easiest way I could bang out a decent functioning mount since my valco flares out so much at the to, the angles are kinda rough. I've used it off and on over the last couple years. The biggest thing I don't like is that since it's all metal connected to the hull, when I go 40+ feet deep I tend to get an evil whine echoing throughout the boat. Still catches fish thoughoverall not too bad. I think when I spring for a second rigger, I may fashion boxes out of wood which should mute the whine, and snag me some Kokanee on both sides of the boat down deep. Also my balls are 6lbs
Much appreciate the info and pics! 6lb balls.... hmmmm LOL I haven't used a downrigger in the area I'm in, bigger boats use big balls, but with only a 12' and not going too far out into the salt, I'll have to experiment. 20-60 feet would be probably the area I'd be in, I'd think nothing more that 80ish. When the tides run against me though, there can be a pretty significant current lifting lines.... the noise issue is interesting, something I hadn't thought of before (have you tried braid? may solve the issue without more construction I'm thinking - I've heard it reduces/stops line singing which is what I'm guessing is transferring to your mount/hull).
