RStewart
hubs are specific to the spindle diameter. looks like you have bearing buddies. after you remove them, there will be a cotter pin that you remove. then remove the nut and the hub will come off. if youu are going to pull bearings out and repack then i have a tip for you. after you remove nut and slide hub off, outside bearing will fall out. put hub back on leaving outside bearing out, and put nut back on. just a few turns will be ok. now, start pulling hub off again but let it slide down the spindle and you will feel the inner bearing catch on the nut. then a couple hard jerks and hub will come off and bearing and seal will be on spindle. hope this makes some sense.idahoguy said:stew6371 said:i see you have dogs. anyway, i would pull hud apart and check bearings. if they are ok, repack then and reassemble. been a lon time since i took one of these apart, but i think there is a seal that you can replace when you reassemble the hub to keep the grease from leakiing out like that.
I do have a dog, but that's not from him.....the previous owner has like 3 dogs.
Are the hubs specific to the trailer? And where do I start when pulling them apart. I really don't want to mess them up.
Seth-
