wmk0002
Ordered some OEM coil kits that come with new plug wires just a little while ago. Hopefully get them in and installed early next week. I'll post an update on everything then. Thanks for the help guys.
RiverLife said:Man I have worked on more motors than I care to admit.
By what your telling me now it's time for a new carb. I have pulled my hair our with similar problems recently with a 15hp Mercury. I would run it in a barrel and it would muck up the water and pump fuel out the exhaust. Plugs were soaked. I rebuild carb and fuel pump and it was worse.
Sometimes carbs won't atomize fuel any longer and need replaced. The Merc 15 starts on one pull idles nice and runs good now with new carb.
Make sure lower unit does not have any fishing line around it and that it spins free and lube is good.
Have confidence in yourself and you will figure it out. Keep at it and keep us posted.
kofkorn said:Pull the carb and look at the float. Not sure when the change happened, but they went from a cork float to a plastic one. The old cork floats can sometimes get "Waterlogged' and will sit lower in the fuel than they should. It causes the fuel level to run higher than it should and can cause a rich condition at open throttle. You don't usually notice it at idle because you adjust for it with the low speed needle. I bought a motor that had this condition. It would run poorly and occasionally stall at WOT. I changed out the float and it ran like new.
Every time I open an carb and see the cork floats, I replace them with a new plastic one. It's not worth the chance.
Good luck!
wmk0002 said:I was able to take the boat out this morning for some fishing and to try out the 9.9hp with the 15hp carb. It ran almost identical to when the 9.9 carb was on and ran well. I only saw a couple hundred more rpms up to 5600 and maybe 0.5-1 mph gain but it still ran good so I guess that at least proves that the 15hp carb is good and isn't the source of my 15hp lacking power. I forgot to take the 15hp fuel pump with me to try that out but will do that next. I'm making some progress here at least.
And if anyone has any ideas why I didn't see the expected rpm gains from the 15 hp carb I'd like to hear them. I know im missing the reed spacers and tuned exhaust tube to go the full way to the 15 hp but I thought the carb alone would do more. Is it still possible the carb has a minor issue like the jet possibly being the wrong one? In a previous post I mentioned I thought it was a jet from a more modern 15hp carb and was a couple thousandths larger than what it should be. I'm certain the throttle plate was fully opening at WOT too.
